pebl-mv
Nov 12, 2024Aspirant
Configuring the Orbi RBR850 kit with an AT&T Fiber BGW320-500 Gateway -fequent DNS errors
Hello, I am using an Orbi RBR850 with the AT&T Fiber BGW320-500 Gateway and followed to the letter AT&T instructions as well as some found in this forum to configure the RBR850 in IP Pathrough mode....
- Jan 03, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
pebl-mv
Nov 13, 2024Aspirant
The firmware version is 7.2.6.31 on the RBR850.
IPv6 is Disabled on my RBR850. Should I turn it on?
IPv6 is available on my BGW320-500 and seems to be enabled.
I am trying to avoid using the RBR850 in AP mode as I was told I would lose some functionality if I did so.
Also as I mentioned before, I am puzzled by the following fact:
My RBR 850 has a MAC address at the bottom of the router, ending with 74. When I go to my BGW320-500 and click on "Device List" I see xx:xx:xx:xx:xx:75 where xx are the same digits as my RBR850 MAC address.
Still in the BGW320-500 configuration under Firewall>IP Passthrough
Passthrough Fixed MAC Address > Device list gave me the MC address ending with 75, but I manually entered the one with 74 at the end. Could that cause issues?
Should I use Dynamic DNS Service on the RBR850 (it is currently unchecked).
Nov 13, 2024Guru - Experienced User
Try the 75 as seen by the ISP modem first.
