pebl-mv
Nov 12, 2024Aspirant
Configuring the Orbi RBR850 kit with an AT&T Fiber BGW320-500 Gateway -fequent DNS errors
Hello, I am using an Orbi RBR850 with the AT&T Fiber BGW320-500 Gateway and followed to the letter AT&T instructions as well as some found in this forum to configure the RBR850 in IP Pathrough mode....
- Jan 03, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
pebl-mv
Nov 15, 2024Aspirant
Thanks FURRYe38.
Nearly 24 hours ago, I changed the MAC address in the BGW320-500 under Firewall>IP Passthrough>Passthrough Fixed MAC Address to the one proposed/seen by the BGW320-500 (the one that ends in 75 instead of 74).
I did several DNS tests afterward which seemed to pass just fine.
I am now in full work mode, as is my wife, and we will see how the day goes.
I do not plan to make any changes to the RBR850 configuration or the BGW320-500 today, and I will most likely wait until another heavy work day (Monday) to see how the RBR850 behaves. I have 20 devices active on my home network, 4 being heavy users of it.
For my curiosity and perhaps the next step, my BGW320-500 supports IPv6, and so is the RBR850. Should I think about enabling IPv6 on the RBR850?
Thanks
pebl-mv
I forgot to mention that the Firmware version on the RBR850 is v7.2.6.31
