trmoore2
Mar 07, 2022Aspirant
Conflicting IP address? (NETGEAR AX4200 Orbi WiFi 6 )
Total layperson when it comes to networking! My Orbi (NETGEAR AX4200) V4.6.5.14_2.0.54 crashes every 3-4 weeks. Even after a reset of the modem (Netgear Model # CM1000V2) and Orbi router,...
trmoore2
Mar 08, 2022Aspirant
There is no “error Message.” A couple of people have mentioned that is the most likely reason. I could be wrong.
Mar 08, 2022Guru - Experienced User
How many wireled and wireless devices do you have all contected at one time?
Does this happen if you remove the switch from the mix?
