trmoore2
Mar 07, 2022Aspirant
Conflicting IP address? (NETGEAR AX4200 Orbi WiFi 6 )
Total layperson when it comes to networking! My Orbi (NETGEAR AX4200) V4.6.5.14_2.0.54 crashes every 3-4 weeks. Even after a reset of the modem (Netgear Model # CM1000V2) and Orbi router,...
Marnli789
Mar 08, 2022Aspirant
trmoore2 wrote:Total layperson when it comes to networking! My Orbi (NETGEAR AX4200)
V4.6.5.14_2.0.54 crashes every 3-4 weeks. Even after a reset of the modem (Netgear Model # CM1000V2) and Orbi router, my hardwired devices will not work. (the wifi usually contines to work). I have to unplug all of my hard wired cables on my "16 port unmanaged Netgear GS316 switch." I reconnect them one by one and this usually fixes the problem. MyAARPMedicare
I've been told i have a duplicate IP address conflict? When I go to the http://orbilogin.net site and check the IP addresses, they seem to be no duplicate IP addresses. I have approximately 20 hard wired devices (thermostats, Roku's, destop computer, etc). Any solution for this problem?
Thanks, Tom
The Netgear Orbi is technically a set of two or more wifi routers that can connect to your existing modem or router (provided by your ISP) to help blanket your home or apartment in Wi-Fi. There are also several Orbi models that include three wifi units to increase the coverage area.
