steveshead
Jun 22, 2022Guide
Connect a satellite via LAN when out of range of the wifi network.
Hi there, New user, new setup! I have just installed RBS850 with two included satellites - works like a charm for the house. I have a third satellite that I want to install in the shop. The shop ...
- Jun 23, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
steveshead
Jun 23, 2022Guide
Thanks for the reply! The part that I'm not sure of is the satellite will be out of range from the Orbi wifi network. The KB article doesn't mention whether I should set it up wireless first, then move it to the shop and connect the LAN cable.
I have a CenturyLink modem - I've plugged the Orbi router into the first LAN port on the modem, then have a 6 port Netgear switch plugged into the Orbi router. From there I have a network cable that goes to the shop.
Cheers
Steve
Jun 23, 2022Guru - Experienced User
It's best to set up the RBS first wirelessly. Do this with the RBS near or in same room as the RBR. Then after it's connected and synced, plug in the RBS to the back of the RBR and let is sync over ethernet. Make sure it reports a "wired" status on the RBRs web page. If you see this, then you can power off the RBS and place at remote location.
What is the model# of the switch you have?
- stevesheadJun 23, 2022Guide
Ah - perfect, thanks - that makes sense. The Netgear is a GS308v3.
Cheers
Steve
- FURRYe38Jun 23, 2022Guru - Experienced User
Ok kewl. Ya that switch should work fine.
I'm gonna try that later today - work is getting in the way of that fun right now! 🙂
Thanks for the assist!
Cheers
Steve
