TR3571's avatar
TR3571
Connect AX6000 Router with AX4200 Router
Hello people,   I have an existing AX4200 Router with 2 Satellites and need to enhance coverage. Have purchased an AX6000 Router with 2 satellites as well. I know that there is a difference in Fron...
  • FURRYe38's avatar
    Yes, you'll have to separate WiFi SSID signals. I would give separate names between these two.
    Be sure to run far apart separate channels between the two.
    Might even lower the transmit power on the 2nd RBR as well from 100% to 50% or 25%.
    It's up to devices to pick and choose where they connect too.
