JacobF
Dec 30, 2024Aspirant
Connect landline to Orbi?
Hi there, I'm using my Orbi RBR350 as the router/modem connected straight to my NBN. Is there any way I can connect a landline to it as well? It doesn't appear to work connecting straight to ...
JacobF
Dec 31, 2024Aspirant
Hi there,
Thanks so much for your response.
Is there an adapter I can purchase that would allow me to plug my normal phone line into the Ethernet port of the Orbi router?
CrimpOn
Jan 01, 2025Guru - Experienced User
It would probably be most efficient to talk to NBN technical support about your options for telephone service.
- JacobFJan 07, 2025Aspirant
Hi there,
The NBN have advised HFC is the only connection at my home, so the only option then is to get a modem/router with a phone line.
However, if the "landline" phone service is via VoIP, is there a compatible handset I could purchase that would be able to be connected to the Orbi via Ethernet?
Many thanks
- FURRYe38Jan 07, 2025Guru - Experienced User
For VoIP and Ethernet phones, yes.
- CrimpOnJan 07, 2025Guru - Experienced User
It might be helpful to read about how the most common VoIP services work:
- https://www.australianphone.com.au/home-phone
- https://www.whichvoip.com/voip/visit_site.php?id=rebtel_oz
- https://www.whichvoip.com/voip/visit_site.php?id=faktortel_oz
- http://www.engin.com.au/
- http://www.exetel.com.au/residential-voip-overview.php
- https://www.mynetfone.com.au/
A significant percentage of people have abandoned their "land line" entirely and rely entirely on cell phones for communication. A lot of VoIP use appears to be concentrated in small business operations where employees "work from home" and a traditional PBX is not appropriate. It may take some investigation to find VoIP for the residential market.
