jdm6
May 27, 2021Follower
Connect Orbi AX6000 WiFi Mesh System (RBK853) and satellites through a switch
Hello, I am looking to purchase Orbi AX6000 WiFi Mesh System (RBK853), but I have a question about the connecting of the devices before purchasing. I would like to wire everything together using ...
May 27, 2021Guru - Experienced User
You can connect the RBR to the switch in AP Mode howver the RBS needs to be connected behind the RBR via ethernet if you connect them in that configuration:
What is the Mfr and model# of the ethernet switch in the configuration?
