WallyMV's avatar
WallyMV
Tutor
Nov 09, 2021
Connect RBR/RBS50 to RBR750
Numerous posts in this community say that it is possible to connect the RBR50 and RBS50 (AC3000) routers and satellites by wired backhaul to the RBR750 (AX4200) and use them as satellites to extend coverage.  After purchasing the RBK752 package and failing to succesfully connect them, Netgear now tells me there is no connection possible, wired or not.
Very dissappointed: my AC3000 units were functioning fine.  I wanted to extend my network to a separate building (with 200 feet of buried Cat 7 cable) and could not find another RBS50 satellite so I upgraded.  Now may be forced to buy another RBS750 satellite, spending hundreds of dollars I apparently did not need to.
I guess buyer beware.
  • FURRYe38's avatar
    RBS AC series are NOT wirelessly compatible with Orbi AX Systems.
    Ethernet, you maybe able to connect the RBS50 via ethernet cable to the back of the RBR and see if they connect. There has been a few users connecting them this way in the past. Not sure if newer FW may not work though.
    • WallyMV's avatar
      WallyMV
      Tutor
      I tried an ethernet connection from the RBR750 to the RBS50.  While the satellite appears in the orbilogin admin page as a wired connection, the Backhaul Status message is Out of Sync.  As soon as I plug it into my network, my mobile device tries to connect and provides an Authentication Error and I lose connection to the wifi. As manual sync of the satellite when connected give me a Satellite Setup Failed message.
      • FURRYe38's avatar
        Unplug the RBS and factory reset it. Turn it OFF.
        Then remove any RBS50 entry on the RBRs web page.
        Power ON the RBS with the RBS connected to ethernet to the back of the RBR...
        Possible that v4 FW may have made the RBS50 not compatible on ethernet now.
