LBnKC
Mar 04, 2022Star
Connect RBS850 to another Satelite?
I have the NETGEAR Orbi Whole Home Tri-band Mesh WiFi 6 Add-on Satellite (RBS850) with a single satellite in the house. I get fair coverage in the barn, however it it not dependable. Can I add ano...
- Mar 04, 2022
You can daisy chain satellites. They only recommend a 2 hop daisy chain but you can do it.
in terms of outdoor satellites, they had ones for AC but I haven't seen any AX compatible satellites (yet?)
Mar 04, 2022Guru - Experienced User
how far away is the barn from the home?
that's the key. If the backhaul doesn't have a decent connection, neither will the satellites.
something you could try would be to buy a cheap 100ft ethernet cable and move the router to where the satellite in the home would be. Then put your signal satellite in the barn and see if it'd connection reliably with the backhaul.
If it does, it should work. If it doesn't, then the point to point system would be the better option to go.
A cheap way to test it.
- LBnKCMar 04, 2022Star
plemanssaid: >> how far away is the barn from the home?
About 75', the satelite to which it would connect is right next to a window with line of sight.
The wifi connection now is three bars (I know, not scientific, I'm not there right now.) Is there any way to determine the backhaul strength? You have not said that they will not work in that way, so may I assume a satellite will connect to a satellite if it has a better signal?
plemanssaid: >> something you could try would be to buy a cheap 100ft ethernet cable and move the router to where the satellite in the home would be.
Since moving to the country I've discovered that simple things like "just grab an Ethernet cable" are harder than they used to be. ;)
"Best" would be a compatible outdoor satellite, but I've not seen any that seem to be compatible (AX). Am I wrong?
- plemansMar 04, 2022Guru - Experienced User
Thanks plemans. Now it's just up to the radio Gods to see if it will work in practice. If not, maybe I can split the difference and put a satellite in an RF-transparent outdoor enclosure.
