JohnScorn
Apr 08, 2022Follower
Connect wifi extender to Orbi AX4200
I have an Orbi AX4200/CBK752. I have ADT Pulse system with wireless cameras. The further camera from the Orbi router frequently goes offline. ADT recommends Netgear wifi extender model WN3000RP. ...
Apr 08, 2022Guru - Experienced User
Yes. Should work ok. Something to try.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
