Hallouminati's avatar
Hallouminati
Follower
Feb 06, 2023
Connecting 2.4ghz RBK753 - Nanoleaf Shapes
I have read through various threads about how to connect to 2.4ghz but have so far not found a solution. The part I have not fully understood is how to do it using hotspot on my iPhone 13. I tried to do it on my own but no joy.
IoT Device - Nanoleaf Shapes
Router - RBK753 Firmware Version V4.6.14.3_2.3.12
Mobile - iPhone 13 iOS16.3
I have spent lots of time with the support team of both Nanoleaf, reaching "sorry, not much we can do, it won't work with anything other than 2.4ghz" (they got logs etc), and Netgear who did spend quite a bit of time with me and I tried two other routers but ultimately no joy (RBK852 and my old RBR20). They did suggest I return the router and get a Nighthawk AX11000 as apparently they can broadcast separate SSID, but the shop won't let me return the router.
Any help of anyone with experience, would be appreciated, thanks.
1 Reply
  • CrimpOn's avatar
    CrimpOn
    (If you had bought  the $19.99 light bulb, I'd have one from Amazon, I'd have one from Amazon in two days......)
    This may be the single biggest issue on the forum for the past six years.  Internet of Things (IoT) devices are engineered with the cheapest WiFi chip possible: one that is capable of 2.4G 802.11/b/g/n.  It has no capability for 5G.  Just like a cordless phone cannot display television picture, these chips cannot detect nor connect to 5G WiFi.  For them, it simply does not exist.  Saying "MUST have 2.4G WiFi" is absolutely correct.  This is like a Ford owners manual saying, "Must have gasoline" or a flashlight saying, "requires 2 C cell batteries."  If you are the only person in the whole world who has a WiFi system without 2.4G, then it cannot work.
    The issue is that some smartphone apps are poorly written. Rather than simply inform the IoT device, "Connect to this WiFi SSID with this password",  they assume that there is a problem when there is no problem.
    95% of the time, my IoT devices connect if I simply tell them, "Continue".  Every time they complain, "MUST have 2.4G WiFi", I just tell them "go on".  And.... they connect.
    I do  notice that Amazon reviews of Nanoleaf Shapes are a bit harsh.  "Cannot connect...." and so on. So, maybe they are one of the companies who bought "a solution" that was not all that great.
    There are several work-arounds for this problem.  They all essentially boil down to this premise:
    • The product will work fine once it has been connected to WiFi the first time.
    • Thus the goal is to convey the WiFi SSID/password to the device.
    • Once the device has connected the first time, it will connect from then on.
    • Some people keep an old WiFi router in a drawer (closet?) that can be hauled out and set up to broadcast the WiFi SSID only on 2.4G.  i.e. power off the house WiFi. Set up this old router. Do the setup. Then put that old router back in the box.
    • Some people create a WiFi Hot Spot on a smartphone that is 2.4G (the default for my Sony Xperia).  Give it exactly the same WiFi SSID/password as the house WiFi. Power off the house WiFi.  Do the setup and then shut down the Hot Spot.
    • Some people turn the Transmit powerof 5G WiFi down to 25% and attempt to get their smartphone far enough away from the WiFi access point that it connects at 2.4G.
    Personally, I would rather send the damn thing back and buy something else.
