Leasy
Jan 28, 2024Aspirant
connecting a orbi satellite to anther netgear modem
hi l have a orbi rbr750 l would like to know if you can connect the satellite to another netgear modem and how to do this can someone help with this please
Jan 28, 2024Guru - Experienced User
Orbi satellites only connect to Orbi routers. Nothing else.
- LeasyJan 29, 2024Aspirant
Thanks for answering my question not what l wanted but l have to work something else out then
- FURRYe38Jan 29, 2024Guru - Experienced User
NGs EX and EAX series wifi extenders are compatible with branded and non branded NG wifi routers.
- LeasyMar 04, 2024Aspirant
yes thats right l am not explaining well
my sats are used wirelessly at the moment but can l hard wire them which would go back to the modem then l would wirelessly connect to them with the tvs phone sonos is this possible
sorry the orbi router
- FURRYe38Mar 05, 2024Guru - Experienced User
RBS can be ethernet connected however they need to be connected behind the RBR:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡 ‌‌🛰️
