Leasy
Jan 28, 2024Aspirant
connecting a orbi satellite to anther netgear modem
hi l have a orbi rbr750 l would like to know if you can connect the satellite to another netgear modem and how to do this can someone help with this please
BullMoon
Jan 31, 2024Apprentice
What sort of Modem? I used to use a Netgear Cable/VOIP Modem (certified for Xfinity) and had my Orbi working with that no problem.
FWIW, the Orbi is a Router, not a Modem. I reckon if your Modem also has a built-in Switch, you could hang all the Orbi gear, routers and sats, off it.
Maybe provide a little more information on what you are trying to do.
Leasy wrote:hi l have a orbi rbr750 l would like to know if you can connect the satellite to another netgear modem and how to do this can someone help with this please
- LeasyMar 04, 2024Aspirant
okay l have an Orbi RBR750 an 3 satellites can l use the l am using the router hard wired and l want to know my bedrooms have ethernet ports in the wall can l use the sats wired thru the wall and then connect the tvs wirelessly
sorry not savvy on this really
