Vahri
Sep 01, 2023Follower
Connecting an ORBI RBRE960 Router to AT&T Fiber with ATT Gateway BGW210-700
#RBRE960 #BGW210-700 #AT&T Can anyone help me with how to install my fancy new ORBI RBRE960 router? I have ATT fiber ISP with an ATT Gateway BGW210-700. I seem to understand that I have to conn...
Sep 01, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Vahri wrote:
#RBRE960
#BGW210-700
#AT&T
Can anyone help me with how to install my fancy new ORBI RBRE960 router? I have ATT fiber ISP with an ATT Gateway BGW210-700. I seem to understand that I have to connect the ORBI directly to the Gateway and convert the Gateway to 'Bridge mode"? I'm not sure how to get there... Current status is connecting the ORBI to the Gateway does not recognize an internet connection so cant proceed with much at all. Has anyone encountered this problem. ATT tech are not being much help.
You might guess I'm not that good with computers / tech :-)- so idiot proof instructions much appreciated if someone knows how to fix this.
Thanks!
