Pabsaudio
Mar 30, 2023Follower
Connecting Orbi direct to Sky/Openreach ONT
I'm sure this has been covered before, but I was unable to find anything. I've recently purchased an Orbi RBS353 mesh system and I want it to replace the Sky supplied router. I have FTTP and an Open...
CrimpOn
Mar 30, 2023Guru - Experienced User
FURRYe38 wrote:
Do you see that option on your RBR750?
Yes. Both options 60 and 61 appear on the RBR750 Internet menu (after scrolling to the bottom). I have a vague memory of one of the SX models leaving off the DHCP options. i.e. SX30 and SX80 have the options, but SX50 did not. And me being surprised, "it's has been on every Netgear router since the beginning of time. Why THIS ONE MODEL doesn't have it???"
I know zero about Sky and whether they specify DHCP options (or not). For that matter, whether they require user login (or not).
There is a long post about Sky fttp and user routers here:
https://helpforum.sky.com/t5/Broadband/Third-party-router-with-FTTP/td-p/3541862
Kewl, hopefully the 3 series has the same.
Thanks for checkin...
