ForestHome
Jun 29, 2021Aspirant
Connecting RBS20s to RBK752 via LAN
I currently have an RBR20 router with two RBS20 satelites and have been very happy with this in most circumstances. Both of my satelites are connected via LAN. I am looking to upgrade to a RBK752 a...
- Jun 29, 2021
Orbi AC 📡 are compatible via ethernet (LAN) connections with Orbi AX.
CrimpOn
Jun 29, 2021Guru - Experienced User
My iimpression is that this is indeed the case. Older Orbi satellites cannot be connected over WiFi because they have different WiFi chipsets that are incompatible with the newer 802.11ax chipsets, but can be connected over ethernet.
In their infinite wisdom, Netgear created separate community forums for many networking products, including separate forums for the original Orbi, Orbi Pro, Orbi Voice, and the new AX Orbi products. People who have successfully connected older satellites to the new AX router may notice the question if it is posted in the AX community forum.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
p.s. What do you have to lose by trying?
ForestHome
Thanks for the reply. I am checking because if I can't use the older satelites then I would be forced to upgrade to the RBK754 to cover the whole house and garage. Because the guest rooms and garage are only needed sporatically, I don't think I would go forward with the upgrade if the older units aren't compatible via LAN.
Second quick question, should I repost this question on the link that you forwarded? If you're confident that it is compatible via LAN then I won't.
- FURRYe38Jun 29, 2021Guru - Experienced User
