ForestHome
Jun 29, 2021Aspirant
Connecting RBS20s to RBK752 via LAN
I currently have an RBR20 router with two RBS20 satelites and have been very happy with this in most circumstances. Both of my satelites are connected via LAN. I am looking to upgrade to a RBK752 a...
- Jun 29, 2021
Orbi AC 📡 are compatible via ethernet (LAN) connections with Orbi AX.
ForestHome
Thanks for the reply. I am checking because if I can't use the older satelites then I would be forced to upgrade to the RBK754 to cover the whole house and garage. Because the guest rooms and garage are only needed sporatically, I don't think I would go forward with the upgrade if the older units aren't compatible via LAN.
Second quick question, should I repost this question on the link that you forwarded? If you're confident that it is compatible via LAN then I won't.
Jun 29, 2021Guru - Experienced User
