Ashraful
May 22, 2023Tutor
Connecting RBS40 Satellite to RBK752 Router
Hi.
I am trying to connect a working RBS40 working satellite to my new Wi-Fi 6 RBR750. I am following the instructions at the ORBI APP but the app isn’t detecting any satellites.
At the end of the process the satellite is with a pink solid light. Is this pairing not possible? Any way to troubleshoot?
They're not compatible. You can't mix the AC satellites with AX equipment.
Here's the orbi compatibility chart.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
1 Reply
