DonDżonson
Sep 28, 2023Tutor
Connecting RBS850 to RBR850
I have problem with connecting new RBS850 to my RBR850. I bought second satellite, and can't connect it. Even when there is info about successful connection, the satellite isn't visible. Also when...
- Sep 29, 2023
Possible that the new RBS is not on same FW version level as your current units. If this is so, you'll need to connect a ethernet connected PC to the back of the RBS and no sync it, wait about 5 minutes. Set a static IP address on your PC for 192.168.1.49. Then see if you can access the RBS web page at 192.168.1.250. if you can, log in with admin and "password". Have the same level RBS FW version file unpacked on the PC and use the RBS web page to upload it to the RBS.
DonDżonson
Sep 29, 2023Tutor
This is beyond me😄
however I did this different way. Connected to router by cable, search in attached devices, look what IP address is, login that way, and updated. After that it appeared as a satellite.
So thanks for help, I couldn't deal with it on my own.
Oct 02, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
