JohnStann
Jul 10, 2021Follower
Connection drops on main network, but works consistently on guest network - ORBI 353
Recently installed new ORBI mesh system all worked fine, 1 week ago went on vacation, used apartments WiFi system no problem. On returning home, devices (all Apple) connected ok but kept saying "No I...
Jul 12, 2021Guru - Experienced User
Are you setting up the RBR via Orbi app or web browser and PC?
Are you giving a custome SSID name and PW when you set up the RBR?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
JohnStann wrote:Recently installed new ORBI mesh system all worked fine, 1 week ago went on vacation, used apartments WiFi system no problem. On returning home, devices (all Apple) connected ok but kept saying "No Internet"..... reset everything several times still no connection to Internet. Turned off the new Apple "block site tracking" function as suggested by on forum, this worked for a while and then reverted to original problem.
Logged on to guest network connected consistently. Reset everything again, tried connecting to main network, still "No Internet", again connected to guest network, working fine.
Any ideas what this could be ?
