naveenezone's avatar
naveenezone
Connection from Satellite to another Satellite using Ethernet
Hello, I have a ORBI Mesh system RBR850.. Can we have Ethernet backhaul by connecting one Satellite ethernet port with another Satellite .For initial sync I connected with Router and satellite but then I need to move to another floor where satellite is connected via Ethernet and I would like to connect this satellite to another Satellite using ethernet.
Please let me know. If this is possible,
1 Reply
  • FURRYe38's avatar
    Best would be to wirelessly connect each RBS to the RBR with the RBS in same room or near the RBR first.
    Then ethernet connect the 1st RBS to the back of the RBR and let it ethernet connect. BLUE LED should be seen on the front of the RBS. Then connect the 2nd RBS to the back of the 1st RBS there. BLUE LED should be seen on the front of the RBS. Once all connected here, power OFF the RBS and place in remote locations and connect them up to there ethernet connections there. Power on the 1st RBS and let it connect and synch fully. Then power on the 2nd RBS and let it connect and sync fully.
