Andrew-Berlin
Dec 06, 2022Aspirant
Connection issues: Orbi RBK753 + Telekom Fiber Modem (Huawei EchoLife HG8010U ONT)
Hi everyone,
I'm hoping for some support on my new Orbi Mesh system.
I have a new Telekom Germany connection. Confirmed with the Fiber Tech team it is reset and functioning on my accoun...
Dec 06, 2022Guru - Experienced User
Have the ISP configure the ONT for the PPPoE account connection then leave the RBR with DHCP configuration on it's Internet side.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Andrew-Berlin
Hi, and thanks for your reply.
Firmware is fully up to date. V4.6.14.3_2.3.12 on router and both sats.
Cable is new cat6 although Orbi ships with cat5e
Telekom Germany requires login via PPPoE, login and password, so there is no way to just let DHCP do its thing.
bringing full setup down and back up also does no good unfortunately......
