tjwing
Sep 11, 2020Initiate
Connection issues with CM1150V modem and AX6000 (RBK853) - both Netgear products
I tried replacing my existing Xfinity model with a Nighthawk CM1150v and Orbi AX6000 (RBK853) tonight. Modem worked fine, but I coule not get the Orbi to connect with the internet. The Orbi was fun...
tjwing
Sep 15, 2020Initiate
Thanks everyone for your responses. After several tries and much research, I learned that while the CM1150v has 4 ports, Comcase only releases one IP address to home plans. Therefore, the other three ports are inactive. I rebooted modem as suggested with nothing plugged in, then plugged in my laptop to port 1 to make sure modem was activated. Once I was sure the modem was activated and able to access internet with the port 1, I unplugged the laptop and plugged in my ORBI. Unfortunately things didn't work. After an hour with NetGear support, they had me do a factory reset on the Orbi and re-install connected to the active port. This we did with a combination of logging in with laptop now connected via ethernet through the ORBI using Orbilogin.net, and the Orbi iPhone app. After successfully reinstalling the ORBI, it worked fine. Have it now running and operating successfully. Only one hiccuo, the next morning my internet was not working because Xfinity chose to deactivate my modem. I had to reactivate the modem by unplugging the ORBI, plugging in my laptop to port 1 on the modem and reactivating it. Turns out that Xfinity activation didn't complete my voice service activation the first time. They thought it was still active on the old modem of theirs and switched everything back over to their old modem that was not even hooked up. Two hours later and multiple customer service calls to Comcast, I got the activation to the new modem completed thoroughly and their records updated to my new CV1150V. Hooked back up the ORBI to port 1 and everything is once again working like a charm.
Hoping no more hiccups. But thanks for all the help. This one was not a simple install. But, in the end, I'm quite pleased with the ORBI performance. Like night an day compared to what Xfinity had me using (which was supposedly their best). Gonna keep the rented router for another week to make sure things go well with this new configuration (CM1150V modem and ORBI AX6000/RBK853). Just got printers in the house working again on the network and a second switch I have for all the media room equipment.
Good to know this is an active community with such strong netrowk backgrounds.
Thanks again!
Sep 16, 2020Guru - Experienced User
Just because the modem has additional ports doesn't mean it's got a router built in. Just be aware that any NG CM series modem with two or more ports does not have a built in router. Only the C series modems has build in router.
It's up to ISPs to control what IP addresses they assigned or allow on these modems with two or more WAN ports. Most only assigned 1 IP address per modem regardless of how many ports are on the back.
Generally just a power cycle (30 sec) of the modem and the connected device, i.e. PC or router is all thats needed to get them connected if the modem has been activated fully and correctly.
