spepet
Feb 24, 2022Aspirant
Connection issues with Microsoft Teams
Since I moved to ORBI WIFI 6 2 weeks ago. I have problems with my Microsoft Teams connection. Every couple of minutes the connection is interrupted for just a couple of seconds. Operation mode: R...
- Feb 26, 2022
Let us know what works...
Feb 24, 2022Guru - Experienced User
How is the PC connected to the system? Wired or wireless?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
- spepetFeb 25, 2022Aspirant
Actual firmware is:
- ORBI router RBR850: V4.6.3.16_2.0.51
- ORBI satellites (2): V4.6.3.16_2.0.51
Internet Service Provider Modem the Orbi router is connect to:
- Model#: TG3492LG-LC
- MFR: did not find the information
Connected PC to ORBI Wifi showing issue:
Model: Dell XPS 15 9500
Connection type: wireless
Home situation:
- Size: 1250 Sq Ft
- Distance from RBS850 satellite 1 to RBS850 satellite 2: 20 ft
- Distance from RBR850 router to RBS850 satellite 2: 40 ft
First I had only RBS850 satellite 1 connecte to RBR850 router with Backhaul status POOR. Then I added RBS850 satellite 2 and RBS850 satellite 1 connected to RBS850 satellite 2 with both Backhaul stauts GOOD.
- FURRYe38Feb 25, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- spepetFeb 25, 2022Aspirant
Thank you very much for the hints. I will reconfigure my environment over weekend and test the result in the Teams calls next week. I found also a former solution from you to a similar problem based on ISP Modem Arris TG3492LG.
