dave1760
Aug 10, 2022Aspirant
connection issues with rbr750
I'm using the orbi RBR750 with 2 satellites and I have it wired back hauled. Lately I'm having issues with my internet speed and it varies by device. It's frustrating to power cycle the router almost...
stevedante
dave1760 wrote:I'm using the orbi RBR750 with 2 satellites and I have it wired back hauled. Lately I'm having issues with my internet speed and it varies by device. It's frustrating to power cycle the router almost on a daily basis to temporarily resolve the issue.
Setup:
Router is downstairs and connected directly to the internet port (no modem)
Both satellites are upstairs
House - 3500 sq ft
On a normal day I would get speeds of 600-800 mbps. When I would run into this issue, I would see speeds below 100mbps. If I ran a speed test directly on the router then I would see 1000mbps. I'm assuming there's a connection issue specifically to the router?
Some solutions I tried:
- Power cycle router (this only solves it for the day and the issue will occur the next day)
- Power cycle router & satellites (this only solves it for the day and the issue will occur the next day)
Any help would be greatly appreciated.
Is you software is working fine, Means Is your router firmware is good and up-do-date? I facing same issue but my firmware is need to be updated.
