dave1760
Aug 10, 2022Aspirant
connection issues with rbr750
I'm using the orbi RBR750 with 2 satellites and I have it wired back hauled. Lately I'm having issues with my internet speed and it varies by device. It's frustrating to power cycle the router almost...
Aug 10, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
For that size of home, only one RBS would be needed. Regardless if wired or wireless.
What CAT# lan cabling are you using between the RBR and ISP modem/ONT and RBS? CAT6 is recommended.
Are the RBS directly connected to the BACK of the RBR or is there any LAN switch or patch panel in between?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Have any of these been enabled? Armor, Access Controls, Parental Controls, or Traffic Meter.
dave1760
I'm using the latest firmware v4.6.8.2
I'm not using a modem as the internet line is connected from the street into my house. My ISP is ziply fiber.
The distance between RBR to my 2 RBS is roughly 30 feet or more. The RBR is located at downstairs in the middle of the house. My RBS is located upstairs at each end of the house. You can say it's diagonally from the RBR.
My house is wired with cat 6 cables and I'm also using them to connect from the wall outlet to each RBS and RBR. Each RBS is directly connected to the RBR and I'm not using a LAN switch or patch panel. My channels are AUTO for 2.4Ghz and 40 for 5Ghz
There's currently 8 wifi neighbor networks within my area.
All of the listed features are turned off: Armor, Access Controls, Parental Controls, or Traffic Meter.
- FURRYe38Aug 10, 2022Guru - Experienced User
Try setting 2.4Ghz channel to 1.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
All of the listed features are turned off: Armor, Access Controls, Parental Controls, or Traffic Meter.- dave1760Aug 15, 2022Aspirant
Tried the suggested solution and issue is still happening. Was on a video call for an hour today and my device disconnected 5 times. My wife is also having trouble with her laptop as well so I'm sure the issue isn't with our devices. My orbi is a little over a year old and don't think it's time for an upgrade.
- FURRYe38Aug 15, 2022Guru - Experienced User
Turn OFF both RBS. See if by connecting to the RBR alone, does the problem still happen?
