Lmourik64
Dec 21, 2022Follower
connection loss between orbi router and satellites after power outage
I have a RGK753 orbi system, 1 router and 2 satellites. Devices are cabled connected via Netgear switches GS108E Router is situated on ground floor next to Ziggo modem and connected to switch ground...
Dec 21, 2022Guru - Experienced User
Be sure that the RBS are connected using the following method with a LAN switch:
The GS108E is a managed switch. If you can find the IGMP and Green Ethernet features on the 108E, disable them to see if this helps any.
Try a NON managed switch to see if this changes the behavior as well. NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
What CAT# lan cable are you using? CAT6 is recommended.
