pemell
Jun 18, 2022Star
Connection refused for certain websites - RBK853 V4.6.8.2
I cannot reach certain websites using my RBK853. It works fine if I connect the computer directly to the fiber media converter (or with mobile data), so the connection and websites are running fine, ...
pemell
Jun 19, 2022Star
Using telnet to connect to the two mentioned websites gives:
"Unable to connect to remote host: Connection timed out"
What on earth is blocking the connection to those websites in my Orbi router. As I mentioned, they load just fine if I connect directly through the fiber media converter.
- plemansJun 20, 2022Guru - Experienced User
have you tried enabling ipv6?
- pemellJun 20, 2022StarJust tried enabling it and setting it to "Auto detect", but issue persists. The websites I mentioned in the first post won't load, which is my insurance company and my standard retailer. It's a big pity they can't be used with an Orbi đ
