pemell
Jun 18, 2022Star
Connection refused for certain websites - RBK853 V4.6.8.2
I cannot reach certain websites using my RBK853. It works fine if I connect the computer directly to the fiber media converter (or with mobile data), so the connection and websites are running fine, ...
Jun 20, 2022Guru - Experienced User
Did you try a different device? Or different browser?
- pemellJun 20, 2022StarYes, it's the same on all devices.
Tested with phone and two laptops directly connected to the fiber media converter = works as expected.
Tested with the same devices, but via Orbi connected to the fiber media converter = won't load.
