doug007
May 13, 2022Tutor
Connection Refused to 192.168.1.1
All of a sudden I'm getting a "can't connect" from the Orbi app to my RBR850. I also get a "Connection Refused" when trying to connect to 192.168.1.1 on my local network. I double-checked, that i...
doug007
May 13, 2022Tutor
Never mind. I finally found the big thread about this issue. Botched firmware update. Factory reset the only way apparently
Snarglefarg
May 15, 2022Initiate
Thanks. I was having the same problem and this thread saved me time finding a solution.
- FURRYe38May 15, 2022Guru - Experienced User
