Sam_Cop
May 19, 2020Guide
Connection Strength in RBK852
Hello, I have 1 gbps connectivity with my WIFI system on a ORBI RBR50 + 2 RBS50. I had to buy an extra RBS50 satellite since I had a poor connectivity between the router and the satellite. WIth "Dai...
Mikey94025
May 19, 2020Hero
Sam_Cop wrote:
- Can I get close to 1 gbps on Wifi 6 devices, like iPhone 11s, iPad Pro etc. (atleast!) in real world scenarios
Sorry, no. IMO believing or hoping for speeds like that is not realistic. It's akin to hoping for 400Mbps on 2.4Ghz networks (the theoretical maximum, but real world 2.4Ghz speeds never got close to that). This Netgear KB article predates AX and states "up to 866 Mbps" for AC: https://kb.netgear.com/31211/At-what-speed-and-bandwidth-can-my-Orbi-system-transmit-data
What you can likely expect is that AX will give you better speeds than AC. I personally get 300-400 Mbps over AX using my iPhone 11 Pro (wifi 6) right up to my Orbi and my cable down speeds are a bit higher than that (just under 1Gbps limit for my plan). Many postings here are from Orbi users complaining that their Orbi is limiting their wired speeds, so your mileage will vary. Some have had success getting close to their 1Gbps plan limit using Orbi just in AP mode and with other features disabled. Once you add wireless, it can only slow down further. I also suspect that handheld, battery-operated devices likes phones are not going to be optimal and have internal bottlenecks when measuring network speed rates.
- Mikey94025May 19, 2020Hero
Mikey94025 wrote:What you can likely expect is that AX will give you better speeds than AC. I personally get 300-400 Mbps over AX using my iPhone 11 Pro (wifi 6) right up to my Orbi and my cable down speeds are a bit higher than that (just under 1Gbps limit for my plan).
Oops, I realized my 6 always-transmitting Nest cameras might be slowing my network down so I disabled them and reran the speedtest app on my iPhone. Now I'm getting high 500s vs. 300s-400s, so a bit better. Recognize there are likely many factors in every environment preventing anything close to 1Gbps optimal speeds, especially over wireless.
