lgreer161
Dec 04, 2022Tutor
Connection to 2.4ghz to set up kasa (tp-link) smart plug mini
I have been trying to find a way to force my phone to use the 2.4ghz network so that I can set up my kasa smart plug which only works with 2.4ghz. I have found these and similar instructions but I do...
CrimpOn
Dec 06, 2022Guru - Experienced User
lgreer161 wrote:
But the prompt in the 2nd screenshot leads me to believe that the Kasa app wants to connect to the temporary TP-Link_SmartPlug_CDF1 wifi.
Yes, I agree.
Unlike cameras (which can take a picture of a QR code) and devices with keyboards, smart plugs have no physical means of inputting the WiFi SSID/password. What appears to happen is that when it is placed into setup mode, the plug creates its own WiFi access point that will accept a connection from any device running the smartphone app. (hmmm. I have not tried to connect without the app. something for another day.) Once the app has a connection to the smart plug, they have some sort of dialog which communicates the WiFi SSID/password to the plug.
After that, the plug turns off the tiny access point and tries to connect to the WiFi system it was told about. Once it gets connected, it can talk to the KASA cloud and say, "This specific KASA plug is associated with a specific KASA user account."
The smartphone app also needs to drop the connection to the mini access point and connect back to the house WiFi.
KASA plugs are interesting in that they do not require the internet connection to function as long as the plug and the smartphone are on the same network.
Would it be convenient to try to add the plug without using the password manager?
lgreer161
Dec 07, 2022Tutor
I have no idea what I did differently but I got it to connect on my 3rd attempt tonight typing in my password manually but I don't think that was it because it didn't connect the first two times typing it manually. All three times I viewed the password and it was correct. I have more plugs to set up so I'll see if I can figure out the pattern. I'll post back here when I do. Got to eat now, it's 8:30pm my time. đ
