SoonerOne
Apr 04, 2020Tutor
Connection-to-AirPort-Express-from-RBK752-Orbi-WiFi-6
I am considering purchasing the RBK752 Orbi WiFi Router Mesh system.I cannot fing any information concerning the possibility of connecting Airport Expresses to the Orbi System. Is that possible? ...
ekhalil
Apr 04, 2020Master
I have my Airport Time Capsule (ATC) wired to Orbi in AP mode. I think you can easily the same setup in AE.
Apr 04, 2020Guru - Experienced User
If you want the AE connected wirelessly, I would recommend that if you get the Orbi AX system in, configure the RBR to use the same SSID name and password as you are currently using on your current wifi router. Then once you get the Orbi AX system online, migration with your wifi devices should be seemless and they should all connect to the Orbi AX system. You may need to reboot your wifi devices.
