frankmeister
Sep 17, 2020Aspirant
Connection to satellite RBS850 much slower than to router RBR850
When my iPhone is connected to the RBR850 router I get download speeds of about 800 Mbps. However when I am connected to anyone of my RBS850 satellites I only get about 90 Mbps down. Strangely enough ...
- Oct 19, 2020
Good to hear. Ya, Cat5 was good at the time. 5e is ok but getting older now and not as good and cat6 and beyond.
Glad you got it working on wireless. Please mark your thread as solves so others will know.
Enjoy. :smileywink:
Sep 18, 2020Guru - Experienced User
Be sure you are connected at the RBS while near it. Disable the iPHones wifi radio for 5 seconds then turn it back on while near the RBS, say 6 feet.
frankmeister
Sep 18, 2020Aspirant
Firmware is the latest and greatest, just updated yesterday: V3.2.16.6
It's the latest and greatest Gigspeed modem/router from Comcast/Xfinity. Why does the model of the ISP router matter when I am getting great speeds from my NG router (it's the satellites that are slow)?
Home is about 5,000sq. Why does that matter when the satellites are connected to router via Ethernet?
Tried turning iPhone on and off, no difference. Staying within 3ft of the satellite when getting the limited speeds.
Could it be that NG skimped on these $350 devices and only put 100Mbps switches in them instead of gigabit switches?
- FURRYe38Sep 18, 2020Guru - Experienced User
I would file a support ticket and contact NG support. Your RBS maybe just faulty and needs replacing.
Gb ports are in the RBS.
- FURRYe38Oct 18, 2020Guru - Experienced User
Any progress on this?
frankmeister wrote:Firmware is the latest and greatest, just updated yesterday: V3.2.16.6
