Jmichaels001
Jul 04, 2020Aspirant
Connectivity issues with Synology 1019+ NAS connected to Orbi RBR850 connected to Motorola modem
Only problems with my Synology NAS. Received replacement NAS and same problem. Sometimes it seems to show on network then it disappears and can’t be located with Synology assistant or find Synology. R...
Jmichaels001
Xfinity gig service through a Motorola MB8600 modem, to the Orbi RBR850. Orbi is running firmware version v3.2.15.25_1.3.15. Orbi is in router mode with 2 satellites working over WiFi I did swap lan cables, using one that came with the Synology NAS. I have not yet tried another port on the back of the router. It appears like NAS is only device with issues but this is a replacement nas so I’m looking for issues in other places. I did turn AX off this morning. It didn’t make a difference
Jul 04, 2020Guru - Experienced User
Try a different port on the back of the RBR...
- Jmichaels001Jul 04, 2020AspirantChanging the port didn’t make any difference
- Mikey94025Jul 05, 2020Hero
Let's try if it matters how the device looking for your NAS is connected - When your NAS device disappears, is it from an app on your phone or something running on a laptop? How is that phone/laptop connected, e.g., is it wireless to a satellite or hardwired to the Orbi router? Do you have any switches between your router and/or satellites?
- Jmichaels001Jul 05, 2020AspirantNo switches. I check both from the laptop and cell phone. Scanning the network it doesn’t show up at all
- FURRYe38Jul 05, 2020Guru - Experienced User
IF other devices work when connected to the RBR and the NAS doesn't, I would presume there maybe a problem with either the cable that runs to the NAS or the NAS itself has a problem.
Jmichaels001 wrote:
Changing the port didn’t make any difference- Chuck_MJul 05, 2020Mentor
Check your private messages: I have a 1019 and am pretty sure we can get it working properly.
