Dolphins
Dec 19, 2021Aspirant
Constant Amber Power LED
Trying to set up the ORBI Router for the first time, the router when plugged into the power supply the power led light stays in a solid amber state. I have tried swapping the power supply with the sa...
Dec 19, 2021Guru - Experienced User
What model Orbi do you have?
If you just got it, you may need to return it for another set.
Dolphins
RBR750 the unit was given to me, it was working when we disconnected at the persons home.
- FURRYe38Dec 19, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?fPower OFF the RBR and disconnect it from the modem and ALL other wired devices. Power ON the RBR by it self. Does the back LED remain amber? Give it a good minute to see if it turns GREEN.
- DolphinsDec 19, 2021Aspirant
Thank You for the assistance. I do not know the firmware version. Modem is a spectrum Arris TM1602A. I have followed your advice several times this afternoon, tried resetting all the ways I could find while researching.I have left the unit plugged in for over an hour to no avail. I was hoping I could at least get connected to the modem so the firmware would possibly load automatically. I followed the steps you had mentioned. I tried to update via my desktop, but I cannot get my CMD to acknowledge the inputs after I turned on the TFTP, I was hoping to transfer over that way.
- plemansDec 20, 2021Guru - Experienced User
where does it fail in the process?
go through what you did in the process (screen snip) so we can see the errors and what you did.
Where did you put the firmware file on the computer? And did you extract it before trying tftp?
There's lots of spots in which tftp can get messed up. Plus it can be sensitive to timings. Sometimes you have to try a few times to get the timing right.
Did you try nmrpflash?
IF two different power supplies are not working, I presume the RBR is faulty. Don't know why the RBR would suddenly fail like this...
