Harrme
Aug 28, 2023Aspirant
Constant buffering RBR750
I have an RBR750 with two satellites. The home is 3,000 sq. ft. The router is in the basement office. Two satellites on the main level. I added the second one after my smart tv on the main level conti...
Harrme
Sep 04, 2023Aspirant
As an update, I moved the new satellite to the tv cabinet/stand and connected the Roku via Ethernet cat6 cable. No buffering anymore. Now, only our mobile devices are having issues. My iPhone can be 8 feet from the second satellite, confirmed as connected to that satellite, appears to have full signal, but can’t get on the internet. Or once I do get on, after a few minutes it goes to continuous buffering. Same for my wife’s phone.
- FURRYe38Sep 04, 2023Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message- HarrmeSep 04, 2023AspirantThank you. I just gave that a try but it didn’t seem to help. Went back on the internet and within 3 minutes it started to buffer continuously.
Power OFF the phones for 1 minute.
Lets try turning OFF just one of the RBS.
Also try this as well, Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 64. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Power ON the phones then test again...
