Harrme
Aug 28, 2023Aspirant
Constant buffering RBR750
I have an RBR750 with two satellites. The home is 3,000 sq. ft. The router is in the basement office. Two satellites on the main level. I added the second one after my smart tv on the main level conti...
Sep 04, 2023Guru - Experienced User
I recommend turning OFF the RBS temporarily and checking for this with just the RBR alone to see if problem still happens, if so, something on the RBR may need to be checked.
Is SIP ALG disabled or enabled on the RBR under Advanced tab/WAN Setup?
Harrme wrote:
I have an RBR750 with two satellites. The home is 3,000 sq. ft. The router is in the basement office. Two satellites on the main level. I added the second one after my smart tv on the main level continued to buffer. Now, the tv drops off the new satellite and continues to connect to the basement router causing non-stop buffering again. Is there any way to assign connections?
Harrme
Sep 04, 2023Aspirant
Turned off RBS. No change.
