Harrme
Aug 28, 2023Aspirant
Constant buffering RBR750
I have an RBR750 with two satellites. The home is 3,000 sq. ft. The router is in the basement office. Two satellites on the main level. I added the second one after my smart tv on the main level conti...
Harrme
Sep 04, 2023Aspirant
Turned off RBS. No change.
Sep 05, 2023Guru - Experienced User
Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Try setting manual channel 1 on 2.4Ghz and 40 channel on 5Ghz.
Enable SIP ALG on the RBR under Advanced tab/WAN Setup.
- HarrmeSep 28, 2023AspirantSo….after weeks of suffering thru Netgear techs, senior tech then Level Two tech, they decide to send me a new router. It arrived today. I followed all the instructions on setting it up. Now, router has solid white light and I can’t access my Orbi app because it says it can’t find my router. My devices will find and connect to the new network, just won’t work. My Level Two tech is off and I won’t hear back from him for a few days. Meanwhile I’m stuck with no functioning internet.
- FURRYe38Sep 28, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
- HarrmeSep 28, 2023AspirantNot sure of manufacturer. It is from Spectrum. Model is EU2251.
Yes. Power off everything by unplugging modem. Plug back in. Get blue connection lights. Power up RBR , goes through pulsing white light Meanwhile I followed prompts on app (set up admin etc). When light went steady white I pushed the blue button on app. It directs to wait while my devices is connecting. Eventually it says Orbi router could not be found. If I go into my phone’s settings, it shows I’m connected to network, but no internet.
- CrimpOnSep 28, 2023Guru - Experienced User
Harrme wrote:
Now, router has solid white light and I can’t access my Orbi app because it says it can’t find my router.Is it correct to assume that you are attempting to Set Up a New Orbi System (bottom item on the drop down menu)?
According to this web page, a solid white light means that the router is ready to set up.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
I am totally old fashioned and prefer to configure routers using a computer connected to one of the LAN ports with a cable.
(There are so many features that are not accessible using the Orbi 'app' that I have never grown accustomed to using it.)
Could you explain more about:
Harrme wrote:
I followed all the instructions on setting it up.Did you use the app? computer browser? ...
- HarrmeSep 28, 2023AspirantYes. Setting up from app. Until it gets to point where it says my Orbi couldn’t be found. Then app is no longer functional
