CMoneyTrading
Jul 30, 2022Aspirant
Constant connection issues for devices [RBRE960B]
My previous Orbi model was great - everything worked smoothly, little issues. I then upgraded to the RBRE960B (due to specs) and wow, this has not been the same experience. I am getting cons...
michaelkenward
Jul 31, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
CMoneyTrading
Jul 31, 2022Aspirant
I'm aware of manuals and searching on forums, thanks. As stated, I had an Orbi and got a new Orbi, while running Netgear modems. Prior to that, I had the Nighthawk. While I was hoping for a quick solution, I've spent hours before even posting here looking for help.
If someone has a useful reply, that'd be great.
