JamesAstroB
Apr 17, 2020Initiate
Constant problems with WiFi 6 RBK852
I just upgraded to the Orbi RBK852 WiFi 6 model, and now I'm having a huge number of problems: • My HP printer is offline, and won't join the WiFi network. I tried resetting its network settings,...
Apr 17, 2020Guru - Experienced User
Please post about this over in the Orbi AX Forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
JamesAstroB
Thank you for the suggestion. I just reposted this in the other forum.
- FURRYe38Apr 17, 2020Guru - Experienced User
Good Luck.
