TanujB
Oct 27, 2020Tutor
Constant speedtest in web client
(My router model is Orbi RBR850 / AX6000 - menu won't let me pick that) I am seeing "constant" speed when I do speedtest in the webclient under Advanced > QoS. Firmware V3.2.16.6_1.4.4. Always th...
Oct 27, 2020Guru - Experienced User
What browser are you using?
Does the speed results show differently if you use a wired PC and Ooklas isntallable speed test app on the PC?
