bduong
Oct 27, 2019Aspirant
Constantly losing internet but still connected to Orbi.
Setup: router: Orbi AX6000 (RBK852 w/ Router and Satellite). internet modem: AT&T Fiber, Wi-Fi Gateway (Arris BGW210-700) - I have the AT&T Router/Modem setup as IP Passthrough and wifi turned off...
Oct 28, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
bduong wrote:Setup:
- I have the AT&T Router/Modem setup as IP Passthrough and wifi turned off. Orbi is connected through lan and setup in Router mode.
I have multiple devices connected to the router:
- Apple TV streaming Youtube TV
- Android TV streaming Youtube TV
- Laptop surfing internet.
I noticed on my Android TV it would constantly buffer (more so than the Apple TV) even though the footage is behind a few minutes. And periodically on my laptop I would lose internet connection even though the laptop is still connected to the Orbi. Tried restarting the router and modem and still seeing the issue. Anyone experiencing this issue? Any advice would help.
