Lee007
Aug 11, 2022Aspirant
COnversion from RBR50 on SPectrum
Question: I just ordered CBR750. My problem is I don't see a tele port for Spectrum phone service. So, can I keep the Spectrum Router, and use the CBR750 as my internet modem only connected to the Spectrum router? OR - must I keep the RBR50 as is?
Thank you Furrye38 . . .thanks for the clarity - well stated and now I will attempt a swap with NetGear.
The CBR750 doesn't have any RJ11 phone support or the port for it. If your needs are or additional Phone support you'll need to use the ISPs modem and your RBR50. If you want Orbi AX something, you could get a RBK752 system to swap in place of the RBR50 system. The RBK series does not have a built in modem as the CBR does.
