DudeDah's avatar
DudeDah
Correct order of steps in replacing Centurylink C3000Z with Orbi RBK852 router
I'm sure this is a dumb question but I'm worried about screwing something up. My ISP's modem/router is a Zyxel c3000z. I have found by going into its configs via a web browser I can turn off the "wir...
  • FURRYe38's avatar
    If it had been synced already, yes, just power it ON. I'd give it several minutes to connect and sync fully. I noticed with mine today, the RBS rebooted a 2nd time before it connected fully and the front LED turned OFF. 5-10 minutes the RBS should be connected. Check the RBRs Connected Devcies page to see it it connects. You can check the modems web page as well to see if it gets an IP address like the RBR. IT should.
