DudeDah
Jan 05, 2022Aspirant
Correct order of steps in replacing Centurylink C3000Z with Orbi RBK852 router
I'm sure this is a dumb question but I'm worried about screwing something up. My ISP's modem/router is a Zyxel c3000z. I have found by going into its configs via a web browser I can turn off the "wir...
- Jan 12, 2022
If it had been synced already, yes, just power it ON. I'd give it several minutes to connect and sync fully. I noticed with mine today, the RBS rebooted a 2nd time before it connected fully and the front LED turned OFF. 5-10 minutes the RBS should be connected. Check the RBRs Connected Devcies page to see it it connects. You can check the modems web page as well to see if it gets an IP address like the RBR. IT should.
DudeDah
Jan 12, 2022Aspirant
OH.
EMM.
GEE!!!
I followed all of those steps exactly. Stayed pink for a WHILE but then checked the ISP modem configs and found the IP for the RBR. I used that IP and was able to log in. Clicked "advanced" then crossed my finger, toes, eyes...and clicked "router/AP mode" and...IT SAYS IT'S IN AP MODE!!! Can't believe it, FINALLY.
So now...I need to connect my Satellite. I have had it unplugged during this process and NORMALLY just plug it in and let it find the RBR. Is it that same process? Just plug it in and see what happens?
I CAN'T thank you enough for sticking with me on this. The easiest solution would have been for me to just use router mode, plug my various ethernet switches into the router and go BUT, I wanted to try and configure this the RIGHT way to get all my wired and wireless devices on the same network.
I think we're getting somewhere...
Jan 12, 2022Guru - Experienced User
- DudeDahJan 13, 2022Aspirant
It all appears to be working. THANK YOU for your pateince in helping me figure this out. It has be a HUGE learning experience and I now understand this all a LITTLE better.
- FURRYe38Jan 13, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - DudeDahJan 13, 2022Aspirant
Another excellent recommendation, thanks.
