tagteam
Dec 16, 2019Virtuoso
Costco has them!
But only a 2-pack! Still the price is good for members comparatively - $549.99
- tagteamVirtuoso
But this is the RBK842 (AX5700) -- 900 + 2400 + 2400Mbps
- DBVApprentice
Any difference between the Costco ones and the Best Buy ones? Must be something since it is $100 price difference. Thanks!
- BanditoLuminary
The Costco system is an RBK842 AC5700 vs. Best Buy's RBK852 AC6000. From the spec sheet on the Netgear website, it appears that the 842 uses a different, 300 Mbps slower, radio on the 2.4 GHz band. That must account for the price difference.
It is the RBK842 which is AX5700 rated (900MHZ on 2.4GHZ Band vs 1.2GHZ on the 2.4 Band of the RBK852 AX6000)
However, everything else seems the same. Not sure if AX6000 is that beneficial over AX5700.
- DBVApprenticeSo - would you buy the Bestbuy one then since it is faster or not worth the extra $100. Guess Costco has better return policy.
