wefjeber
Sep 10, 2020Aspirant
COSTCO RBR750 2 Satellites slow wired speeds
I just bought an OBI RBR750 from Costco with 2 Satellites. My home has Cox Gigablast (1,000MB/S) and is wired so each Satellite has the wired backhaul. In my office, I use Satellite 1's additio...
Oct 20, 2020Guru - Experienced User
Any progress on this?
What is the Mfr and model# of the ethernet switch in the configuration?
HappyFlavor
Oct 26, 2020Aspirant
I am running rbr750 and a NETGEAR Nighthawk CM1100 DOCSIS 3.1 Cable Modem. House in 5000 sq ft. Router is upstairs on south side of house, Satalite 1 is on North side of house and is connect via WiFi , Satalite 2 is downstairs connect via Ethernet .
- FURRYe38Oct 26, 2020Guru - Experienced User
Are the RBS directly connected to the RBR or is there a network switch in between the RBR and RBS?
If there is one, What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System - HappyFlavorOct 26, 2020Aspirant
One Statlite is directly connected to the 750 , the other is connect via "wifi". I have the Cox Giga and standing directly in front of the RBR750 I get max wifi speeds of 250mps, and its only worse as i walk away from it.
What happens if you swap the RBS with each other? See if the problem follows and tracks with the working RBS.
Be sure your using good quality LAN cable. CAT6 is recommended.
The issue is not that one Satalite is working and the other is not, they are both showing up in the Orbi App Network Diagram and "working" the problem is that the degradation of the speed in wifi is much greater then the projected 30%. I am only getting 250 mps max (standing directly in front of the router) on a Giga Connection. I will check on the quality of the cable.
