wefjeber
Sep 10, 2020Aspirant
COSTCO RBR750 2 Satellites slow wired speeds
I just bought an OBI RBR750 from Costco with 2 Satellites. My home has Cox Gigablast (1,000MB/S) and is wired so each Satellite has the wired backhaul. In my office, I use Satellite 1's additio...
HappyFlavor
Oct 26, 2020Aspirant
I am running rbr750 and a NETGEAR Nighthawk CM1100 DOCSIS 3.1 Cable Modem. House in 5000 sq ft. Router is upstairs on south side of house, Satalite 1 is on North side of house and is connect via WiFi , Satalite 2 is downstairs connect via Ethernet .
Oct 26, 2020Guru - Experienced User
Are the RBS directly connected to the RBR or is there a network switch in between the RBR and RBS?
If there is one, What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
